Split Expression
I have expression Tag ,value type String A/B/C/D/N/M I would like to use direct expression to return the string always the last two parts after / means, result for above example A/B/C/D
other example
A/B/C/D/E/F/G return should be A/B/C/D/E
With my Integration Toolkit module:
transform(
	split({[.]SourceStringTag}, '/'), // delivers a dataset, one part per row
	groupConcat( // Assembles from rows like python .join()
		where(
			value(),  // The split result
			idx() < len(value()) - 2  // True for all but the last two rows
		0, // Pick from column zero (the only one)
		'/' // Rejoin with the same character
Something with a script if you don't have my toolkit.
Below example is based on an expression tag in the same folder as a memory tag (FullTag) with a value of the full string.
To return everything before last "/":
left({[.]FullTag}, lastIndexOf({[.]FullTag}, "/"))
So, to return everything before second-to-last "/":
:nauseated_face:
