SQL Bridge Named Query Tag Historian
Hi everyone,
I have a debit on configuration, If I setup a gateway without install sql bridge, named query and sql script work anyway? Tag Historian is fully independent by SQL Bridge?
Yes.
SQL Bridge, despite the name, is not required for DB access. The module adds Transaction Groups to the system. Transaction groups provide a UI for setting up some useful methods of moving data from a device to a DB and in the opposite direction. However, they do not provide anything that is not achievable through other methods.
Named Queries and Scripting are part of the base Ignition package.
Tag Historian is an independent module from SQL Bridge and neither is dependent upon the other.
