SQL, checking multiple dynamic parameters
I am trying to figure out how how I can configure the parameters in my where clause for my query to receive a list of the Skus to evaluate in the sorting.
I know I need to work on my ranking too, but I think I can get that easy enough.
select
rank() over (partition by Line order by Net desc, Sku) as LineRank, Sku, Net, Scrap
from myTable
where Sku in (     )
group by Line
If I have like 20 skus, I don't want to do a big case statement.
I am seeing some different implementations online, but none are really the thing.
I thought maybe I could pass a byte array that gets set from an expression tag binding.
These were close:
sql server 2008 - SQL Where clause with dynamic IN() operator - Stack Overflow
I think this one might work, where he passes a string that he parses. I might do this implementation.
c# - Execute stored procedure with array-like string separated by comma - Stack Overflow
You can use a querystring instead of a value,
You'll have to parse the value correct ofc with quotes and commas
Are you using a named query or a scripting function?
I planned to use a named query.
edit: If I ran a script, I use named queries runPrepUpdate in those cases.
Thanks Victor
I think that is what I will use. Looks efficient.
You should never use queryString parameters with user input. You can sanitize your dropdowns with indirection, but any text search fields are a security breach waiting to happen.
If scripting, construct "Prep" queries with the correct number of question marks and make sure your argument list matches. If not scripting, reconsider.
As a specific example of @pturmel's suggestion:
Thanks for helping me.
I wasn't using queryString.
I was using a table component with a named query that had parameter to bind to a component on the perspective page.
I use runPrepUpdate() in scripts.
I had a typing error in my previous post. Sorry for the confusion.
Oh, Victor's example is a queryString. I did not realize that till just now.
I will probably use @zacht's example code in a script.
Before I get my list of Skus to get ranks though:
What would be a good component to let users efficiently pick which of 20 Skus they wanted to utilize in the query?
I think clicking on 20 radial dials or check boxes would be terrible.
I would like to have maybe a drag selection maybe if possible, so maybe a user could draw a box around some to add to the current list.
Or maybe I can have them in a table that they can click and drag on that I could color, is that doable?
