SQL database ID column not iterable
Hi, I’m trying to access a dataset object that I created in a script. The object is made up of the row id’s from a sql table. Here is the code:
  for row in dataset:
dBdeviceID = row[3]
I want to take the rows from this set and add them to an array so that I can use them in another part of my script but every time I try to access the “dBdeviceID” set I get an error saying it is imutable, that it can’t be iterated over etc. Does anyone know how to do this?
Is it a dataset or Pydataset?
https://docs.inductiveautomation.com/display/DOC79/Datasets
It is a Pydataset that was converted from an ignition dataset.
In the code that you posted you are repeatedly assigning a value to the variable dBdeviceID.
If dBdeviceID is defined as an array or a list you should use append().
for row in dataset:
    dBdeviceID.append(row[3])
Or use a list comprehension one-liner:
Column3 = [row[3] for row in dataset]
If the original dataset inherits from an AbstractDataset (likely), you can skip the conversion and do this:
Column3 = list(originalDS.getColumnAsList(3))
The latter is blistering fast, if that matters in your case.
