This is my code:
clientname = event.source.parent.getComponent('Group').getComponent('Text Field').text
dateofwork = event.source.parent.getComponent('Group').getComponent('Text Field 1').text
progress = event.source.parent.getComponent('Group').getComponent('Numeric Text Field').intValue
sitelocation = event.source.parent.getComponent('Group').getComponent('Text Field 2').text
problem = event.source.parent.getComponent('Group').getComponent('Text Field 3').text
resolution = event.source.parent.getComponent('Group').getComponent('Text Area').text
timespent = event.source.parent.getComponent('Text Field 3').text
db = "DB"
updateQuery = """UPDATE workorders SET clientname = ?, dateofwork = ?, progress = ?, sitelocation = ?, problem = ? resolution = ?, timespent = ? WHERE dateofwork = ?"""
system.db.runPrepUpdate(updateQuery, [clientname, dateofwork, progress, sitelocation, problem, resolution, timespent, dateofwork], db)
I keep getting an error that says:
[quote]Traceback (most recent call last):
File “event:actionPerformed”, line 10, in
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE workorders SET clientname = ?, dateofwork = ?, progress = ?, sitelocation = ?, problem = ? resolution = ?, timespent = ? WHERE dateofwork = ?, [Sonerra, 6/4/2015, 75, Soaring Eagle, Bent Antennae, Reset Antennae and made sure cows could not get to it, 3 hour, 6/4/2015], DB, , false, false)
caused by Exception: Error executing system.db.runPrepUpdate(UPDATE workorders SET clientname = ?, dateofwork = ?, progress = ?, sitelocation = ?, problem = ? resolution = ?, timespent = ? WHERE dateofwork = ?, [Sonerra, 6/4/2015, 75, Soaring Eagle, Bent Antennae, Reset Antennae and made sure cows could not get to it, 3 hour, 6/4/2015], DB, , false, false)
caused by GatewayException: SQL error for "UPDATE workorders SET clientname = ?, dateofwork = ?, progress = ?, sitelocation = ?, problem = ? resolution = ?, timespent = ? WHERE dateofwork = ?": You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'resolution = 'Reset Antennae and made sure cows could not get to it', timespent ' at line 1
caused by MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'resolution = 'Reset Antennae and made sure cows could not get to it', timespent ' at line 1
Ignition v7.7.5 (b2015071516)
Java: Oracle Corporation 1.7.0_71
[/quote]
the issue I’m having is that it is saying to look at the issue at line one, but i don’t even see where any of the referenced error is in line 1!
A little confused to say the least
