Maybe someone could point out to me where I am going wrong?
I have the following table created:
CREATE TABLE REPORT_WTW2
DateofReport varchar(10),
SiteName varchar(50),
Weather varchar(10),
Caretaker varchar (100),
Using a button on a window I have the following script:
date1 = event.source.parent.getComponent(‘Label Day’).text
date1 = date1 + “-”
date1 = date1 + event.source.parent.getComponent(‘Label 7’).text
date1 = date1 + “-”
date1 = date1 + event.source.parent.getComponent(‘Label 9’).text
site1 = str(event.source.parent.getComponent(‘Dropdown Site’).selectedStringValue)
weather = str(event.source.parent.getComponent(‘Dropdown’).selectedStringValue)
caretaker = str(event.source.parent.getComponent(‘Dropdown Care’).selectedStringValue)
system.db.runUpdateQuery(“INSERT INTO REPORT_WTW2 (DateofReport, SiteName, Weather, Caretaker) VALUES (%s, %s, %s, %s)” % (date1, site1, weather, caretaker))
I am getting the following error:
File “event:actionPerformed”, line 12, in
java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery(INSERT INTO REPORT_WTW2 (DateofReport, SiteName, Weather, Caretaker) VALUES (19-02-2014, testsitename, Dry, John McCarney), , , false)
caused by Exception: Error executing system.db.runUpdateQuery(INSERT INTO REPORT_WTW2 (DateofReport, SiteName, Weather, Caretaker) VALUES (19-02-2014, testsitename, Dry, John McCarney), , , false)
caused by GatewayException: SQL error for "INSERT INTO REPORT_WTW2 (DateofReport, SiteName, Weather, Caretaker) VALUES (19-02-2014, testsitename, Dry, John McCarney)": Incorrect syntax near 'McCarney'.
caused by SQLServerException: Incorrect syntax near 'McCarney'.
