I have a table on that is using this SQL statement;
[code]SELECT
FROM
dwg_list
{Root Container.tblDwgList.whereClause}[/code]
Where Clause
if({Root Container.txtDwgID.text} = "",
	 concat("WHERE cntlr_id =", {Root Container.drpCntlrName.selectedValue}),
	 	concat("WHERE dwg_id =", {Root Container.txtDwgID.text}))
Error
[code]Exception: Error running query:
SQLQuery(query=SELECT
FROM
dwg_list
WHERE dwg_id =40_1000-Layout1.pdf, database=)@5000ms
On: Main Window 1.Root Container.tblDwgList.data
caused by GatewayException: Unknown column ‘40_1000’ in ‘where clause’
caused by MySQLSyntaxErrorException: Unknown column ‘40_1000’ in ‘where clause’
Ignition v7.5.0 (b1079)
Java: Oracle Corporation 1.7.0_05
[/code]
When I type into the ‘Root Container.txtDwgID.text’ text box ‘40_1000-Layout1.pdf’ i get the above error.
But if I change the SQL statement to
[code]
SELECT
FROM
dwg_list
WHERE dwg_id =‘40_1000-Layout1.pdf’[/code]
The query works
