SQL Historian minimum database permissions
When creating an SQL user for SQL Historian, what basic permissions are required?
  • SELECT
  • INSERT
  • UPDATE
  • DELETE
  • CREATE
  • DROP
I assume that, at minimum, we need these in order to add tags and inject our data:
  • CREATE
  • INSERT
  • SELECT
And if Ignition manages partitioning, I assume we also need to be able to purge unused tags and drop partitions:
  • DROP
  • DELETE
UPDATE doesn't seem applicable, as I'm not aware that Ignition modifies any written data?
Thanks!
Metadata.
Yeah, Ignition needs basically full permissions to do all the things it does with the SQL database.
Rows in sqlth_partitions, sqlth_te and probably other tables I'm forgetting about will need to be updated over time. If it's a concern, create a dedicated schema/"database" and a specific Ignition user in your DB that only has access there.
