I have a querry that will insert a new record into my DB listed below, but now I want to be able to updat the “setupsheet” if it already exist.
queryValue1 = event.source.parent.getComponent('MoldName').selectedStringValue
queryValue2 = event.source.parent.getComponent('MachineName').selectedStringValue
queryValue3 = event.source.parent.getComponent('Text Area').text
if system.gui.confirm("Steve! Are you sure you want to Save changes?",
"Save Changes"):
system.db.runPrepUpdate("INSERT INTO setup_sheetlist (MoldName,machineName,Setupsheet) VALUES ('%s','%s','%s')" % (queryValue1, queryValue2 , queryValue3), getKey=1)
This is my query, its working in my DB but I’m a lost on how to implement it into the RunPrepUpdate,
IF EXISTS( SELECT * FROM setup_sheetlist WHERE moldname='100SCX-3' AND Machinename='MM11')
UPDATE setup_sheetlist
SET setupsheet ='updated value 3'
ELSE
INSERT INTO setup_sheetlist(MoldName,machineName,Setupsheet)
VALUES('100SCX-3','MM11','TRIAL 2')[/code]
This is what I have so far, this gi9ves me an error message
[code]Error: java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(IF EXISTS( SELECT * FROM setup_sheetlist WHERE moldname='?' AND Machinename='?')UPDATE setup_sheetlist SET setupsheet ='updated value 3' WHERE moldname='?' AND Machinename='?', [100SCX-3, MM09, 100SCX-3, MM09], , , false, false)
caused by Exception: Error executing system.db.runPrepUpdate(IF EXISTS( SELECT * FROM setup_sheetlist WHERE moldname='?' AND Machinename='?')UPDATE setup_sheetlist SET setupsheet ='updated value 3' WHERE moldname='?' AND Machinename='?', [100SCX-3, MM09, 100SCX-3, MM09], , , false, false)
caused by GatewayException: SQL error for "IF EXISTS( SELECT * FROM setup_sheetlist WHERE moldname='?' AND Machinename='?')UPDATE setup_sheetlist SET setupsheet ='updated value 3' WHERE moldname='?' AND Machinename='?'": The index 1 is out of range.
caused by SQLServerException: The index 1 is out of range.
[code]queryValue1 = event.source.parent.getComponent(‘MoldName’).selectedStringValue
queryValue2 = event.source.parent.getComponent(‘MachineName’).selectedStringValue
queryValue3 = event.source.parent.getComponent(‘Text Area’).text
if system.gui.confirm(“Steve! Are you sure you want to Save changes?”,
“Save Changes”):
system.db.runPrepUpdate("IF EXISTS( SELECT * FROM setup_sheetlist WHERE moldname='?' AND Machinename='?')UPDATE setup_sheetlist SET setupsheet ='updated value 3' WHERE moldname='?' AND Machinename='?'" ,[queryValue1,queryValue2,queryValue1,queryValue2] )
ELSE
INSERT
INTO
VALUES ('%s','%s','%s')" % (queryValue1, queryValue2 , queryValue3))
[/code]
