This below statement works great.
system.db.runPrepUpdate(“INSERT INTO QC_CupMeasurements_Temp (testValue) VALUES (?)”, [testValue],“Ignition”)
But I want to add “WHERE sampleID = somevariable”
Whats the syntax? I know I am going to facepalm when I see it.
Try this:
SELECT something FROM sometable
adamaustin, I get the SQL syntax, I was referring to the syntax as it relates to putting the SQL statement within the system.db.runPrepUpdate statement.
Specifically here is my issue:
sampleID1 = 02-20140522100349
t1Leak1 = 25
system.db.runPrepUpdate("INSERT INTO QC_CupMeasurements_Temp (t1Leak) VALUES (?) SELECT sampleID,t1Leak FROM QC_CupMeasurements_Temp WHERE (sampleID) = (?)", (t1Leak1),(sampleID1),"Ignition")
Result is an error:
[code]Traceback (most recent call last):
File “”, line 3, in
java.lang.ClassCastException: java.lang.ClassCastException: Cannot coerce value ‘25’ into type: class [Ljava.lang.Object;
caused by ClassCastException: Cannot coerce value '25' into type: class [Ljava.lang.Object;
Ignition v7.6.4 (b2013112117)
Java: Oracle Corporation 1.7.0_51
[/code]
Try:
system.db.runPrepUpdate("""INSERT INTO QC_CupMeasurements_Temp (testValue)
WHERE sampleID = ?""", [somevariable],"Ignition")
Try:
system.db.runPrepUpdate("INSERT INTO QC_CupMeasurements_Temp (SAMPLEID, t1Leak) SELECT sampleID, ? FROM QC_CupMeasurements_Temp WHERE (sampleID) = (?)", [t1Leak1,sampleID1],"Ignition")
I wanted to use UPDATE not INSERT…
DOH!!
