I am trying to create a chart that extracts the amount of operational hours from the database organized by month. Basically cell utilization chart. I have 'timestamp' data in the database as well as "Cycle Time" for each operation formatted in minutes. I have tried several methods. So far this is the only part of the code I can get to work:
SELECT CAST (Timestamp AS DATE) FROM PartData_Log
My best guess is to generate cases for every month then sum the "Cycle Time" by those cases but I have been unable to make that work
It sounds as though you want a SUM function which will require use of the GROUP BY operation.
SELECT
CAST(Timestamp AS DATE) AS Date,
SUM(Minutes) AS CumulativeMinutes
FROM PartData_Log
WHERE
TimeStamp >= :startDate
AND
TimeStamp < :endDate
GROUP BY CAST(Timestamp AS DATE)
Try this out in the Named Query editor and create variables for the :startDate and :endDate parameters.
FROM PartData_Log
Where
("Timestamp") >= DATEADD (MONTH,-11,DATEFROMPARTS(YEAR(GETDATE()),MONTH(GETDATE()),1))
Group By
DATENAME (MONTH,("Timestamp"))
order by
MAX ("Timestamp")
Now my problem is that I have three column's of data output and I only want to use the first two. It is messing up my chart. How do I suppress one of the column outputs in my chart?
SELECT DATENAME (MONTH,("Timestamp")) ,SUM ("Cycle Time")/3600,MAX ("Timestamp")
FROM PartData_Log
Where
Group By
order by
MAX ("Timestamp")
THanks for looking at it. I basically want to turn off one column of data produced by the query "timestamp". We are using the timestamp for another column but I don't need the data directly. I can remove the column in ignition and it works but only in testing. Once I save it, it reverts to include all three, column's of data
Maybe there is another way to get ignition to ignore this column?
You might add which chart component is using this data. I haven't used Vision for quite a while so you may need someone more familiar with it but there should be a way of selecting which columns to display..
Tips:
Be consistent in your upper/lowercase for SQL keywords. You've got some in uppercase and some in proper case and some in lowercase.
Add a space after every comma, as in standard English.
"Timestamp" shouldn't need ( ) brackets other than for the MAX function.
Don't be afraid to break lines for legibility.
SELECT
DATENAME(MONTH, "Timestamp"),
SUM("Cycle Time") / 3600,
MAX("Timestamp")
FROM PartData_Log
WHERE
Timestamp >= DATEADD(
MONTH,
-11,
DATEFROMPARTS(YEAR(GETDATE()), MONTH(GETDATE()), 1)
GROUP BY
ORDER BY MAX("Timestamp")
When we make your SQL readable we can see that you have asked for three columns in the SELECT statement.
