A particular gateway I'm working with is giving odd results when returning queries that contain a time type. When I make the query in SSMS (this is MS SQL) the times retuned are correct although they have a date component. When the same query is done inside Ignition, either via script of the Query Browser, they are off by one hour (less). The time zone of the gateway is correct and anyway wasn't even aware that SQL datetime or time types were time zone aware.
I do understand that the returned time type is cast into a java Date time so the date is always Jan 1, 1900 which is fine. I'm just perplexed about the time being off and unsure of how to address it. Any help would be appreciated.
Here's an example query:
SELECT start_time FROM _shift WHERE department_id=? AND shift_number=?
When issued from Ignition I get: 1900-01-01 06:00:00.000. When done in SSMS I get 07:00:00.0000000
Kurt
