I’m experimenting problems when executing SQL queries containing either temp tables or variable tables, this queries run perfectly on the SQL server, however in Ignition I get this message:
Exception: Error running query:
SQLQuery(query=
CREATE TABLE #kk(t_stamp datetime, EA_FUERZA_P5 bigint,Incremento bigint)
INSERT INTO #kk SELECT t_stamp,EA_FUERZA_P5,Incremento=
LEAD(EA_FUERZA_P5) OVER (ORDER BY t_stamp)-EA_FUERZA_P5
FROM Consumos
SELECT DATEPART(Hour,t_stamp),SUM(Incremento)
FROM #kk
WHERE DAY(t_stamp)=DAY(‘2013-4-9’)
GROUP BY DATEPART(Hour,t_stamp)
DROP TABLE #kk, database=TORRELAGUNA_HIST)@5000ms
On: Main Window.Root Container.Table 1.data
caused by GatewayException: La instrucción no devolvió un conjunto de resultados.
caused by SQLServerException: La instrucción no devolvió un conjunto de resultados.
Ignition v7.5.6 (b1317)
Java: Oracle Corporation 1.7.0_17
I need to clarify as soon as possible if these tables are supported in Ignition, since they’re vital for our development.
