SQL Queries using CTE and With
The last several gateways I worked on, I was not able to use CTE or With in a named query.
Did an update enable using those or was there a setting all along to use them?
The WITH keyword confuses the auto-detection of update versus query mode. Recent versions allow you to force one mode or the other. (It's been quite a while, I think.)
Do you use them or avoid using CTE and With keywords in the named queries?
I have multiple queries where I use the same base query 4 times.
Usually I get main range I need.
Then I get the edge case.
Usually I reuse both subqueries again to union total to the bottom row.
I use CTEs when I need them. There are two such situations:
  • I need recursion that can only be expressed with a CTE, or
  • I need an identical subquery in two (or more) places in an outer query--the duplicate subquery is then factored into a CTE for performance.
I don't use CTEs as an alternate syntax for general subqueries.
