I have a SQL query to calculate the production rate of a machine based on the count now and the count an hour ago. The trouble is that it errors out if there is now data or if the query returns a divide by zero. I need to encapsulate the query within an expression or script to test the values ahead of time or provide a failover. The query is as follows:
Select CAST((max(Count)-min(Count)) / (DatePart(mi,max(t_stamp) - min(t_stamp))) AS DECIMAL(5,2)) as "BPM"
FROM Case_Inkjets
WHERE EquipID = {Root Container.P0248.EquipID} and
t_stamp > DateAdd(hh,-1,GetDate()) and
Count > 0
What do you suggest?
