SQL Query Property Binding Missing in Perspective
Hi all,
Is there currently no way to configure a SQL Query property binding aside from a named query or a runScript expression in 8.0 Perspective? I believe we were able to write the Query within the binding manually if needed.
Or am I missing a better solution here? The use case is to containerize this query in a template/view that I can share around. It works fine for tags/named queries/runScripts, but I would like to avoid these if I can.
Cheers,
Roger
Direct SQL queries are deliberately absent from Perspective - they’re 1. a big security problem and 2. harder to optimize.
If you can’t achieve what you want with named queries, then DB access through scripting is the recommended approach.
Ahhh, makes sense! Thanks for the info. I think we’ll use the named query approach for this particular view, I’ve used it everywhere else but this window.
Best,
Roger
