I’m trying to export data from an SQL database to an excel spread sheet. Using posts on the forum this is working OK, the problem is when I try to select a data range using the “Where” command I keep getting syntax errors!
My database table has 7 colums and I am selecting the data using the colum LogName and a Dropdown List called Location with a returned value in “where” (as per demo project)
Code
Loc = event.source.parent.getComponent(‘Location’).where
Filename = “Report.xls”
results = system.db.runQuery("SELECT RejectData_UpperThreshold, RejectData_SystemNoise, RejectData_Trigger, RejectDateTime, RejectData_LowerThreshold, RejectData_LeakSize,LogName FROM report WHERE (event.source.parent.getComponent(‘Location’).where) ORDER BY LogName ASC ",“NewConnection”)
result = system.dataset.toDataSet(results)
HeaderRow = [0,1,2,3,4,5,6]
Heading = system.dataset.addRow(result,0,HeaderRow)
spreadsheet = system.dataset.dataSetToExcel(1, [Heading])
filePath = “C:\output\” + Filename
system.file.writeFile(filePath, spreadsheet)
system.net.openURL(“C:\output\” + Filename)[/color]
The error is in line 3 results= …
Any help would be appreciated as this is driving me mad
Regards Tom
