SQL Query Tag - I want null returned as 0
So I have a SQL Query Tag that returns a Workorder. Later on in the process I use that Work Order number to query something else to give me production information. When the tag is [color=#FF0000]null[/color] and I try to use that value to lookup production information I get errors… But if I manually substitute a ZERO it works. Is it possible within the tag defenition somewhere to assign a default value? OR am I missing something in my SQL code that will do this?
SELECT TOP 1 WorkOrderNumber FROM MachineWorkOrders WHERE MachineID='{[.]Lane3}' ORDER BY StartDate DESC
No matter what the great Google box gives me as possible answers I an unable to accomplish this…
Try COALESCE:
SELECT TOP 1 COALESCE(WorkOrderNumber,0) FROM MachineWorkOrders WHERE MachineID='{[.]Lane3}' ORDER BY StartDate DESC
Nope. Still the tag shows null. I have attached 2 screenshots… I have tried ISNULL () function also with the same result.
Hmm… does the row for the work order exist?
Maybe something like this:
SELECT CASE WHEN EXISTS(SELECT TOP 1 COALESCE(WorkOrderNumber,0) FROM MachineWorkOrders WHERE MachineID='{[.]Lane3}' ORDER BY StartDate DESC) THEN (SELECT TOP 1 COALESCE(WorkOrderNumber,0) FROM MachineWorkOrders WHERE MachineID='{[.]Lane3}' ORDER BY StartDate DESC) ELSE '0' END
EDIT: Probably without the COALESCE… getting tired… :unamused:
No the row for the workorder does NOT exist… That is why I am trying to return a ZERO instead of nothing.
Ah. Then that last one I posted should be closer.
Another option is to use an expression tag to coalesce the first one.
Now there’s a thought… hmmmm.
Since there is is no record returned with your WHERE clause, there is noting to coalesce. But you can put your Select statement inside the coalesce.
Try - SELECT COALESCE( (SELECT TOP 1 WorkOrderNumber FROM MachineWorkOrders WHERE MachineID='{[.]Lane3}' ORDER BY StartDate DESC), "WooHoo It Works")
Your Suggestion is very useful, i success.
Here’s one of my Queries for “Divide By Error”. I am using MSSQL.
You will probably just use the ISNULL function, something like this.
ISNULL(Column, 0) The 0 will replace the NULL value.
SELECT Top 30 t_stamp, DailyWater, Daily_Inj_Runtime, ISNULL(DailyWater / NULLIF(Daily_inj_Runtime,0),0)*60.0 as PHFR from injection order by t_stamp desc
