Fallback values for SQL expressions have been touched on before, but with quite the same problem.
I have been trying to come up with a query that will return something, even when there is no record found in the table.
I enabled the ‘Fallback Value’ feature and set to 0 which worked well for numeric values.
Ideally i would like to bind the Fallback Value to an Ignition tag. Why is this not possible?
What i am trying to achieve is; Query for a value in a table. If query returns no rows, then the record has not been created yet, and i want to set some default values. These should be provided by an Ignition tag.
I have tried to use various queries using “CASE” and “COALESCE”. Unfortunately i can’t get CASE to return something using “ELSE”, and i get errors from Ignition saying no rows are found.
Current query i am using:
[code]SELECT
CASE
WHEN EXISTS (SELECT ProductID FROM QAFingerJointTest WHERE Test_ID = ‘{Root Container.ContainerFingerJoint.Text Field Test ID.text}’) THEN ProductID
ELSE ‘{Gisborne01/ProdSystems/ProdRecipe/ProdRcp_ProductID/Value}’
END AS prodID
FROM
QAFingerJointTest
WHERE
Test_ID = ‘{Root Container.ContainerFingerJoint.Text Field Test ID.text}’[/code]
