SQL Scripting For Tables
I am creating an SQL query, I have the the following types of values
I would like to filter by the largest "id", I want to only show the top 5 largest "id" values, and display only the eventtime and the source on the table.
My current query that exclusively displays all of the values for each column is below.
I had worked on this for a while, but continue to write SQL scripts that yield no data.
What is the database?
For MariaDB/MYSql something like this should work:
SELECT source,eventtime FROM alarm_events ORDER BY id DESC LIMIT 5
As @bschroeder suggested. An ORDER BY with a row limit would work. Depending on the DB flavor, the syntax for the row limit will differ. See this page for examples: SQL SELECT TOP, LIMIT, ROWNUM.
