I have setup a test server I have successfully connected the db to the gateway. I can view and interact with the gateway in the designer. However when I launch the client it, the connection isn’t working, Anyone have any ideas about what is going on?
Is this a new project in a version of Ignition >= 7.9.3? If so, did you turn on legacy DB access for the project? (It’s no longer enabled by default)
That was it! Thank you
