SQL Server Update Query: Is it possible to get the return code?
I am wondering if it's possible to get the return code from the stored procedure when I run an update query. "Update", in this context, is the Ignition query type, the actual procedure runs a couple of insert statements.
Stored Procedures return a code, depending on success or failure, and I would like to get the zero code on success to tell the user that the inserts were successful.
The update query takes a bunch of parameters, sends those to the sproc.
query = 'myUpdateQuery'
params = {about 40 items...}
system.perspective.runNamedQuery(query, params)
Query statement:
EXEC dbo.usp_InsertSurveyData  :p1,  :p2,  :p3,  :p4,  :p5,  :p6,  :p7, :p8, :p9,  :p10,  :p11,  :p12,
	:p13,  :p14,  :p15,  :p16,  :p17,  :p18,  :p19,  :p20,  :p21,  :p22,  :p23,  :p24,  :p25,  :p26,
	:p27,  :p28,  :p29,  :p30,  :p31,  :p32,  :p33,  :p34,  :p35,  :p36,  :p37,  :p38,  :p39,  :dept,  :shift,  :position
If I change this to a "Scalar Query" and attempt to get the result...it does not work.
Anyone know of a way to do this?
Did you check the return code you are currently getting?
(You may need to script the procedure call and use an output parameter. Named queries can't do that.)
well, the only return code I get by default is zero. Unless I specify the return code like RETURN 4, I get 0. But this I do in the SSMS.
Is there a "best practice" for getting a confirmation of an update/insert? Would that be the scripting you mentioned?
That's SQL scripting. Don't do that.
Just use a plain SQL INSERT or UPDATE statement (no DECLAREs or BEGINs or other SQL script syntax) and you will automatically get the number of affected rows as the return value.
And how do I get this returned value into Ignition?
Most things in system.*.* are functions. Use retv = system.some.thing(...) to collect a return value into a local python variable.
