Sql tag expression
Would I be able to do this within a sql expression for example:
select * from(select top 1 pname FROM sqlth_partitions order by end_time desc)
in order to make searching through a history tag dynamic
It sounds possible. What’s stopping you?
[quote=“Julio.Bautista, post:1, topic:16876”]
[/quote
well when I try to run it on the sql query browser on ignition I get this error
You will need to alias the subquery.
select * from (select top 1 pname FROM sqlth_partitions order by end_time desc) subquery1
https://www.techonthenet.com/sql_server/subqueries.php
While you do need to alias a sub-query to make it work, this query isn’t going to return what you’re looking for. The top level query only returns a subset of the sub-query (if that makes sense).
What it seems like you’re trying to do is select all the history data for the last partition that was created. For that you’d need to do a dynamic sql statements.
declare @stmt nvarchar(250)
select top 1 @stmt = 'select * from ’ + pname FROM sqlth_partitions order by end_time desc
exec sp_executesql @stmt
