Is there a way to get the SQL Tag export to XML to order by tag name? It would really make repetitive tag entry a lot easier. I’ve seen a Pytgon script in an earlier post that will sort it for you but this should really be a native feature (if it’s not already).
Also, I can’t determine what the XML output is actually sorted on?
