Does the SQL tags import utility import from a CSV file from RSLOGIX 5000.
I tried and Ignition gave me a error
java.lang.Exception: Unknown CSV format
at com.inductiveautomation.ignition.designer.sqltags.action.ImportTagAction$CSVTagImporter.run(ImportTagAction.java:142)
at com.inductiveautomation.ignition.client.util.gui.ProgressDialog$TaskRunner.run(ProgressDialog.java:208)
at java.lang.Thread.run(Unknown Source)
Ignition v7.1.5 (b5670)
Java: Sun Microsystems Inc. 1.6.0_18
I guess I figured it out. I used the Ignition Export and can clearly see that it is not in the same format.
So my next question would be , what would be the best way to develop screens when you dont have a live PLC to quickly drag and drop tags. Instead of typing 500 tags in?
You certainly don’t need live PLC tags to develop screens, but having the tags themselves (even though they will be either simulated or stale) will be helpful.
Also, typing in 500 tags by hand sounds like a bad strategy. Most of our customers find ways to coerce their tag lists into our CSV format via copy/paste or macros.
I found a processor and got it tied into ignition. I browsed the tags in the OPC and dragged them to the SQL tags. There is probally 900 tags I believe mabye more, Now that I did that Ignition is unstable and java is running at 90% of the computers memory.
