I’ve been working with David Fogle and Tom ??? on this, but I’m still having issues so I thought I’d post my issue to see if anyone else has had this issue.
I have several thousand SQL tags, and only some of them are not reading. If I turn on a BOOL tag, the PLC receives the info and turns on the tag, but then when the SQL tag reads that same OPC tag, it thinks it is off, when it’s really on. This phenomenon is only present to some of my SQL tags - the others read/write correctly.
Any help would be appreciated. Thank you!
