I added a bunch of SQL tags via the FPMI SQL Tags browser by dragging the tags from the OPC Browser. It took quite a while, so I thought it would be faster if I used the Import feature instead. So, I exported the tags to see what the cvs file looks like, but don’t quite understand what I’m seeing.
I am using the Kepware OPC Server, and use dot names so my tags are organized much more logically (this creates groups in Kepware). For instance, my OPC tag names would look like this:
Machine_1.Inputs.ProxSw
Machine_1.Outputs.Solenoid
Machine_2.Inputs.ProxSw
Machine_2.Outputs.Solenoid
I’ve always done it this way, and as far as I can tell, I haven’t had a problem with my project running at the customer site.
But, when I export the tags form the tag browser, I get something like this:
Path Name TagType DataType Enabled AccessRights
Machine_1 6 2 TRUE Read_Write
Machine_1/ Inputs 6 2 TRUE Read_Write
Machine_1/Inputs/ ProxSw 0 1 TRUE Read_Write
I’m not sure why the tab formatting isn’t preserved, but the first two items have a TagType and DataType of 6 and 2. These are the first two parts of the dot names, and aren’t really tags. Is that what 6 and 2 mean, or are they artifacts? Do I also need to give them Enabled and AccessRights properties? Or can I just ignore these altogether when I create my own cvs file to import, and just include the actual tags? I just want to understand this correctly.
