I have a button that allows data to be reordered via a sort order field in a table. It works great, most of the time. Occasionally if clicking the move up or move down button rapidly it is possible to end up with two rows with the same sort order. This situation requires manual recovery. Is there any way to prevent this occurrence? I have tried adding a running flag, but that does not seem to have any effect.
From the actionPerformed on the order button:
[code]OrderNumber = event.source.parent.getComponent(‘Sequence Table’).OrderNumber
data = event.source.parent.getComponent(‘Sequence Table’).data
row = event.source.parent.getComponent(‘Sequence Table’).selectedRow
Running = event.source.Running
if row > 0 and Running != 1:
event.source.Running = 1
currentSort = data.getValueAt(row,“SortOrder”)
#get previous record
sql = “SELECT TOP 1 ORDER_NUMBER FROM tblSequence WHERE SortOrder < %d ORDER BY SortOrder DESC”
omsPrev = system.db.runScalarQuery(sql %(currentSort))
sql = “UPDATE tblSequence SET SortOrder = SortOrder + 1 WHERE ORDER_NUMBER = ?”
system.db.runPrepUpdate(sql, [omsPrev])
sql = “UPDATE tblSequence SET SortOrder = SortOrder - 1 WHERE ORDER_NUMBER = ?”
system.db.runPrepUpdate(sql, [OrderNumber])
event.source.parent.getComponent('Sequence Table').selectedRow = row -1
system.db.refresh(event.source.parent,"Sequence")
event.source.Running = 0
[/code]
