SQL Transactions Skipping Entries
Hi everyone!
We are facing an issue where we are attempting to batch sql entries as a transaction. The script loops through a list of sql queries and attempts to execute them, however when the transaction is committed only the last query in the list is actually committed to the database.
	try:
		tx_id = system.db.beginTransaction(timeout = 10000)
		for sql in sql_lines:
			print sql
	   		logger.info(sql)
	   		sql.strip()
	        system.db.runUpdateQuery(sql, database_name, tx_id)
		#Commit all the transactions and close the connection
		system.db.commitTransaction(tx_id)
		system.db.closeTransaction(tx_id)
	except Exception as e:
		system.db.rollbackTransaction(tx_id)
		logger.error(traceback.format_exc())
		logger.error("SQL Transaction Failure, check the logs")
Each sql line is a simple insert statement and running them against the database by itself works perfectly fine, it's just the transaction that is messing up.
Might also be important to note that this script is in a gateway message handler.
It's important to note that no exceptions are logged and it says the transaction was successfully committed. In the logs we can see every sql line from that "logger.info(sql)" statement as well.
Is there some sort of weird syntax error or an issue with how I am using transactions?
Thanks!
Check your return values from runUpdateQuery. (Why aren't you using runPrepUpdate()? .runUpdateQuery is not safe with dynamic data.)
Also, what security are you applying to the message handler? If you are passing raw SQL in messages, you are opening a HUGE security hole.
Thanks for your reply, and you bring up very good points. The SQL queries we are using are completely static. Additionally, we aren't at the point with security just yet since we are just testing right now but they will 100% be encoded. Everything is on a completely isolated network so figured it would be fine for testing dummy values at the moment.
As for the return values it is also odd, I've added logging to capture each return value in the for loop but I still face the issue where it will only display the very last entry (as a 1 since it is an insert and affects a single row).
So basically the logs will show something from bottom to top like...
1 (last return value)
INSERT INTO..
INSERT INTO...
INSERT INTO....
Still unsure why it decides to skip entries completely...
Thanks!
I see it. You have spaces on that one line where your other indentation is with tabs.
Python requires consistent use of whitespace to separate logical blocks of code.
Also, don't use print in gateway scope. That pollutes your wrapper.log file.
The whitespace in the designer has once again tried to end me.
Thank you so much!
Right-click in the editor ...
