I don't understand where i need to put the Where clause in my SQL update script. This is on an action performed script on a button and i created this from an Insert script that works. I can Insert and Delete from the table but i can't figure out where to put the Where in the query so it updates the data based on the UniqueID. I'm using MSSQL if that helps.
def runAction(self, event):
value1 = self.custom.ParamIDNew
value2 = self.custom.POMPropertyPKNew
value3 = self.custom.POMPropertyNameNew
value4 = self.custom.POMMultiValueNameNew
value5 = self.custom.UserName
value6 = self.custom.Comments
value7 = self.custom.UniqueID
if value6 !="":
query = "UPDATE MESParameterIDs (Parameter_ID,POMPropertyPK,POMPropertyName,POMMultiValueName,UserName,Comments) VALUES (?,?,?,?,?,?)"
args = [value1,value2,value3,value4,value5,value6]
system.db.runPrepUpdate(query, args)
lrose
March 5, 2024, 4:49pm
2
It would go after the Set statement:
query = """
SET Parameter_ID = ?,
POMPropertyPK = ?,
POMPropertyName = ?,
POMMultiValueName = ?,
UserName = ?,
Comments = ?
WHERE UniqueID = ?
Then add value7 to your args list.
I've never seen a SQL UPDATE statement with that syntax. Go back to your DB's user manual.
(Update is totally different from Insert.)
lrose
March 5, 2024, 5:01pm
4
You're right, as usual. ID10T error. Corrected.
@John_Williams
SQL update syntax looks like this: SQL UPDATE Statement
Not like this: SQL INSERT INTO Statement
edit: sorry @lrose replied to wrong person
Thanks guys. I don't know what i was thinking. Posting the updated script for anyone else that might need it below.
if value6 !="":
query = "UPDATE MESParameterIDs SET Parameter_ID = ?,POMPropertyPK = ?,POMPropertyName = ?,POMMultiValueName = ?,UserName =?,Comments = ? WHERE UniqueID = ?"
args = [value1,value2,value3,value4,value5,value6,value7]
Tips: Add a space after commas in your queries and lists of arguments - same as regular English. It makes reading easier and aids wordwrap in some circumstances. Use the triple-quotes to wrap SQL query strings as shown by lrose.
Thanks. I was wondering why it had triple quotes.
if value6 !="":
query = """
POMPropertyPK = ?,
UserName = ?,
Comments = ?
WHERE UniqueID = ?
args = [value1, value2, value3, value4, value5, value6, value7]
lrose
March 5, 2024, 7:25pm
9
Personally, I would make a custom property of object type with a structure like this:
{"POM": {
"ID",
"PropertyPK",
"PropertyName",
"MultiValueName",
"UserName",
"Comments",
"UniqueID"
If each of those things is bound to something, then use an Expression Structure to bind all of them.
Create a parameterized Named Query, and make sure that your parameters are named the same as the keys in your structure.
SET Parameter_ID = :ID
POMPropertyPK = :PropertyPK
POMPropertyName = :PropertyName
POMMultiValueName = :MultiValueName
UserName = :UserName
Comments = :Comments
WHERE UniqueID = :UniqueID
Then your runAction script becomes:
system.db.runNamedQuery("Path/To/NamedQuery", self.custom.POM)
