When I start the designer in SQLBridge, after I select the project I want to work on I get this null pointer exception and the designer closes. My coworker can open the designer on his PC and everything works just fine. I have accessed SQLBridge and updated projects as well in the past from my PC. Any ideas?
java.lang.NullPointerException
at com.inductiveautomation.ignition.designer.DesignerContextProxy.getTagManager(DesignerContextProxy.java:138)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCTreeModel.(OPCTreeModel.java:27)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCBrowserBasePanel.itemStateChanged(OPCBrowserBasePanel.java:144)
at javax.swing.JComboBox.fireItemStateChanged(Unknown Source)
at javax.swing.JComboBox.selectedItemChanged(Unknown Source)
at javax.swing.JComboBox.contentsChanged(Unknown Source)
at javax.swing.AbstractListModel.fireContentsChanged(Unknown Source)
at javax.swing.DefaultComboBoxModel.setSelectedItem(Unknown Source)
at com.inductiveautomation.ignition.designer.gui.AbstractProfileOptionDropdown.setSelectedItem(AbstractProfileOptionDropdown.java:82)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCBrowserBasePanel.setProvider(OPCBrowserBasePanel.java:133)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCBrowserPanel.lazyInit(OPCBrowserPanel.java:89)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCBrowserPanel$1.dockableFrameShown(OPCBrowserPanel.java:81)
at com.jidesoft.docking.DockableFrame.fireDockableFrameEvent(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.m(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.s(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.h(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.resetToDefault(Unknown Source)
at com.jidesoft.swing.LayoutPersistenceManager.resetToDefault(Unknown Source)
at com.jidesoft.swing.AbstractLayoutPersistence.loadLayoutDataFrom(Unknown Source)
at com.inductiveautomation.ignition.designer.WorkspaceManager.install(WorkspaceManager.java:200)
at com.inductiveautomation.ignition.designer.WorkspaceManager.setSelected(WorkspaceManager.java:129)
at com.inductiveautomation.ignition.designer.WorkspaceManager.access$000(WorkspaceManager.java:30)
at com.inductiveautomation.ignition.designer.WorkspaceManager$1.run(WorkspaceManager.java:104)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
Ignition v7.4.3 (b995)
Java: Sun Microsystems Inc. 1.6.0_26
