SQLite Database Backup Restore
Hello folks,
Is there any way to backup and restore the SQLite database? I trying with complete gateway backup it does not restoring SQLite database.
Any leads other way to do this?
Thank you
Srikanth P
A gateway backup absolutely restores the main config.idb SQLite file that contains all gateway configuration.
A gateway backup does not contain e.g. Edge’s historian buffer, or any ‘local’ audit profile, alarm journal, etc data - by design.
Thanks for the reply @paul-griffith
Example : I have created some tables in SQLite for testing purpose and sending gateway backup to my team member and restored the backup in his laptop, the tables which I was created in my laptop it won’t reflect in his backup along with data.
This is where we are facing an issue. Every time we are creating a table and doing the activities.
Regards,
Srikanth P
Send the database separately. As Paul points out, this backup behavior is intended, not a bug. Managing databases is a user responsibility.
Sure will manage the database, could you please tell us how to make separate backup and restore the same (SQLite)
SQLite stores everything in a single file. You should disable the DB connection in Ignition, copy that file to a backup folder, then re-enable the DB connection.
If you need a DB that can be backed up on the run, use something else.
