I have created a udt where each member is a separate sqlquery tag. This seemed chatty so I combined them into one sqlquery tag with a datatype of dataset which worked well. Now, I need to trend and alarm on each of the columns in the dataset. I tried creating a new memory tag for each column and referencing the dataset within the udt. I couldn’t seem to get that to work. I then tried a value changed script on the sqlquery tag with the aim of writing directly to the other members of the udt.
Is this the right approach or am I way off? If so, what is the syntax to resolve the row/column in the dataset. Note, there will only be 1 row in the dataset.
