Sqlt_data {variable} t_stamp
Hello, how can I make a query that search in all registers?
Should i make a variable for year and month?
Use the tag history binding. It uses all appropriate tables for the time range you give it.
Is not any way to do it with SQL?
Not in a single binding, no. You would need to use a union that repeats your query as many times as time ranges indicate. Complicated. Tag history bindings and functions do this for you.
How can we make a time filter in that case? for example just sow the register between 0 am to 8 am?
Tag History Bindings allow you to specify the date/time start and end.
I mean, to filter every day the data range. If i select one data range(1 week), and i just want to see some hour at day(2pm to 3pm). I have made other filters abiables in the table but this as i understand is more easy to make in SQL, how can i make in the tag history bildings?
I would use a history binding for the full time span on a custom component and then post-process that dataset to apply the additional conditions. Naturally, I would use my own view() expression function for the post-processing. (:
I was doing that, make some variables to filter in a table. but is a manual work…
Thanks any how. :grinning:
