to have a better readability ?
Ex.
select case when count(*)>0 then 'TRUE'
else 'FALSE'
end
from t_users where name ='toto' and pwd ='titi'
instead of
select case when count(*)>0 then 'TRUE' else 'FALSE' end from t_users where name ='toto' and pwd ='titi'
If you’re doing this in a area where you’re writing Python code (which offhand is the only place I can think of that might give you some trouble with formatting like this), just surround your SQL statement in a set of triple quotation marks. So, for example, you would do:
SQL = """select case when count(*)>0 then 'TRUE'
else 'FALSE'
end
from t_users where name ='toto' and pwd ='titi'"""
system.db.runQuery(SQL)
