I’ve downloaded from Extras and tested the “SQLTags Alarm Edit” window for Ignition.
I have found two ‘bugs’:
In the table ‘Tags’ the Data property has query:
SELECT
c.id,
c.path,
c.name,
m.intval as alerttype
FROM
sqlt_core c, sqlt_meta m
WHERE
m.tagid = c.id AND AND c.tagtype IN (0,1,2) AND m.name = 'alertmode' AND m.intval > 0
ORDER BY
c.path ASC, c.name ASC
I found that the m.name should be ‘AlertMode’ (field name in sqlt_as table) and “c.deleted = 0 AND” must be added (to get the right tags):
SELECT
c.id,
c.path,
c.name,
FROM
WHERE
m.tagid = c.id AND c.deleted = 0 AND c.tagtype IN (0,1,2) AND m.name = 'AlertMode' AND m.intval > 0
ORDER BY
in order to work.
When you change some properties in ‘Digital Settings’ and click ‘Save’ button, the TimeDeadBand and TimeDeadBandUnits are not saved (because they are not in the script for Save button). When you select the tag again in ‘Tags’ table, you see ‘0’ (zero) and
Thanks for brining that up to our attention. We are planning on recreating this goodie using some built-in functions. Those screens only work for tags stored in an external provider. We want to make this work for any tags regardless of where they are stored.
