Ignition 7.5.6 (b1317) trial
Have a UDT “PAC3200” with folder structure and OPC tags to communicate with Siemens PAC3200 power monitor.
Created duplicate tagname in UDT, to that added manually in an instance of a PAC3200 UDT. This appears to have been cause of problem.
Image attached.
Windows using the PAC3200 instances remain running so it appears to be a browsing bug.
Have tried to remove the duplicate tag in UDT but problem persists.
Console shows
ERROR [TagTreeNode-AWT-EventQueue-0] Error loading children of node: Power_Meter
java.lang.RuntimeException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:491)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:473)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.browse(ClientTagManagerImpl.java:277)
at com.inductiveautomation.ignition.designer.sqltags.tree.TagTreeNode.loadChildren(TagTreeNode.java:227)
at com.inductiveautomation.ignition.designer.sqltags.tree.AbstractTagPathTreeNode$Loader.run(AbstractTagPathTreeNode.java:79)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:722)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:244)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:797)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.browse(DatasourceTagManager.java:488)
… 10 more
Caused by: java.lang.NullPointerException
at com.inductiveautomation.ignition.common.sqltags.TagDefinition.(TagDefinition.java:128)
at com.inductiveautomation.ignition.common.sqltags.TagDefinition.(TagDefinition.java:119)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.SQLTags.wrap(SQLTags.java:256)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.SQLTags.browse(SQLTags.java:134)
at sun.reflect.GeneratedMethodAccessor35.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:176)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:398)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
… 1 more
