Hi!
We’re running Ignition 7.3.0 (b460) and it seems that this version has some problems with SQLtags. E.g. opc tags seems to lose its properties, such as “OPC server”, “OPC item path” etc. And this happens to all tags, which in our case is several hundreds of them. But If I go to configuration page and click “save” under my SQLtags provider setting, then everything goes back to normal, but after a while everything loses again.
In our previous Ignition version (I don’t know the version number because we’re not hosting server) SQLtags worked fine.
regards
-Heikki
