In order to get SQLTags working with Oracle, it is necessary to edit the Driver settings in order to specify a custom key retrieval function.
To do this (assuming that you’ve already installed the oracle driver into FactoryPMI):
Log into the FactoryPMI gateway, click on “Drivers”, and then edit the Oracle driver
Set the following:
Supports Returning Auto-generated Keys? FALSE
Fetch Key Query:SELECT ${table_name}_SEQUENCE.CURRVAL from dual -
Apply, and restart the server (a soft restart from the link is sufficient). With FactorySQL also configured for the database, you should now be able to use SQLTags in FactoryPMI.
