Hi, I find that there is an interface named " SQLTagsManager" in Ignition 7.9.
But I did not find that interface in ignition 8.0. Is this class deprecated? Is there any alternative interface ?
GatewayTagManager is probably the equivalent in 8.0: http://files.inductiveautomation.com/sdk/javadoc/ignition80/8.0.14/com/inductiveautomation/ignition/gateway/tags/model/GatewayTagManager.html
Thanks.
Morning sir. Another question.
The previous class âTagProviderâ from âcom.inductiveautomation.ignition.gateway.sqltagsâ has also changed.
I find that there is another âTagProviderâ in âcom.inductiveautomation.ignition.common.tags.modelâ. But there are some methods missing.
Is there another alternative class for the previous âTagProviderâ in ignition sdk 7.9?
How can I find the all the changes in ignition sdk 8.0?
You already found the new TagProvider. What are you trying to accomplish?
There are a lot of changes in the gateway/SDK between 7.9 and 8.0 and there is no guide or documented that details all of them. The javadocs and example modules are all that is available.
There is a method âbrowseTagInfoâ in the package of my team. It will return a âBrowserResultsâ
I am not sure how to replace it.
Well thatâs not on TagProvider, itâs on the old SQLTagsManager.
The replacement is probably TagManager#browseAsync
