Hi all,
I was doing some reading in the Ignition Database Table Reference and noticed that a tag can be retired for the following reasons.
- The tag was deleted
- The tag group on the tag was changed, which results in a new row being created with the updated
scid- The tag was renamed
I ran a query to check how many of each I had.
SELECT count(*) FROM sqlth_te where retired IS NOT NULL
~33000 tags
SELECT count(*) FROM sqlth_te where retired IS NULL
~5000 tags
Looks like a lot of tags records can be deleted but I wanted to check to see if anyone has done this.
- Should I periodically delete records that have a retired value?
- Would I even gain anything by doing so?
- What are the downsides of doing so?
- Any other database tips I should be doing for this table or other Ignition tables?
