Square root function sqrt() in script
How to correctly include and run the square root function in scripts?
I try
import math
print math.sqrt(4)
but obtain
AttributeError: ‘com.inductiveautomation.ignition.designer.gui.tool’ object has no attribute ‘sqrt’
Ignition 8.0.15
Where are you trying to run the script?
Works for me in Script Console 8.0.14
I am trying in script console too
I’d try deleting your cache, and letting it download a fresh copy from the gateway.
Without result(
A project colleague on a different machine has the same problem
Ok, seems pow() is working, so I will use it
Strange problem with such popular function…
Thanks to all
Do you have a project script named math?
Oh really it exists
Now it is clear.
Thank you!
