Hello,
I created a Windows VM, acting as a development server, with the same specifications as my main server. Ignition 8.1.45.
Then I loaded the backup of the main server on the development server.
Unfortunately, the SSL certificates are not being included in the gwbk file. With SAML active, this makes it impossible to access the gateway because the callback can only go on HTTPS.
The webserver TLS certificates are considered an aspect of the Ignition "installation" with 8.1.x and are not currently included in GWBK's. You'll need to copy the webserver/ssl.pfx file from your main server's Ignition installation. You should be able to place the file in the same folder on your development server and then restart Ignition, it should then have TLS enabled.
