I went ahead and setup SSL and I’m able to access the web interface via HTTPS just fine; however, when I launch Designer, I noticed the following in the Java console, (see attached). Why isn’t this HTTPS?
Right now we have to use the regular HTTP port when initially launching the application. As soon as it is launched it switches over to HTTPS for all traffic. This is something that we will fix in 7.6. Your client is running over HTTPS and you can verify it by selecting Help > About Ignition Vision from the client’s menu. You will see the connected gateway is HTTPS.
