Dear all,
i have enabled SSL/TLS in Ignition in order to ensure secure access. It has all the certificates asked by the tool. I have also enabled the redirection so any traffic going through http is redirected to https. and now the application is not reachable anymore! what can I do to at least recover what I has before?
Thanks a lot
Patricia
hello @patricia.mendez,
What version of ignition are you on?
There are a number of requirements when using SSL, If you have a certificate signed by a trusted CA it should work, if you do not you will need to add the certificate on the client machines to allow communications. If you have done this, you could target the https://[gw]:[sslPort] directly in the launchers and see if this improves your experience.
