Stacked bar chart from dataset
Hi all,
I’d like to display the following dataset using an XYChart as a stacked bar chart:
I’m having issues figuring out how to configure the XYChart.
Column WMS_CUTOFF should be x-axis,
y-axis would be the stacked ORDER_STATE with AMOUNT.
New to this and wasn’t able to find an exact manual.
Thanks!
This should send you in the right direction.
Thanks - that helped me a ton!
Just needed to edit my query so I pivot every state in its own column.
Thanks :slight_smile:
