Our database contains approx. 35k tags. We are getting multiple session timeouts, some tags are not coming through and at times show as “stale”.
Does anyone know a fix or know how to decrease poll rate, increase timeouts or stale threshold?
Check in your tag group for stale timeouts and poll rates. What are your poll rates in there?
Tag groups are assigned to individual tags so you could be using multiple different groups
What is your gateway server cpu utilisation at?
What version igntion?
Are you using Perspective or vision?
When you say session timeouts, is there an error and what does it say specifically?
What are the load factors of your devices? (check the gateway status page under status - > devices)
How do I check this?
What version ignition?
8.0.15
Vision
DiskDataStore
java.io.FileNotFoundException: C:\Windows\Temp\jetty-0_0_0_0-8060-main-_-any-17619979785291176608.dir\WicketFilter-filestore\1302\7801\node01jlxlmicio8u1ef23n4irghj752\data (The system cannot find the path specified)
at java.base/java.io.RandomAccessFile.open0(Native Method)
at java.base/java.io.RandomAccessFile.open(Unknown Source)
at java.base/java.io.RandomAccessFile.(Unknown Source)
at org.apache.wicket.pageStore.DiskDataStore$SessionEntry.getFileChannel(DiskDataStore.java:425)
at org.apache.wicket.pageStore.DiskDataStore$SessionEntry.savePage(DiskDataStore.java:343)
at org.apache.wicket.pageStore.DiskDataStore.storeData(DiskDataStore.java:181)
at org.apache.wicket.pageStore.AsynchronousDataStore$PageSavingRunnable.run(AsynchronousDataStore.java:355)
No devices connected. Using OPC-UA
