Has anyone used Starlink Business services for SMS (SMS Module)? I wanted to know how well this works, is it reliable? Also what web based service are you using for VOIP (Voice Module) ? I would like some recommendations for the SIP-Voice service rather than blindly picking any online service provider. Thank You.
I don't use Ignition's voice module myself, but I do run a VOIP client for Asterisk into my office through StarLink (in a tunnel). I would not expect Starlink itself to cause you any trouble.
Thanks for your feedback. I haven't heard of Asterisk. I am assuming you are referring to SIP Trunking ⋆ Asterisk
Yes, I run Asterisk for my office phones, in the cloud. So the trunk isn't over Starlink, but the SIP connection from desk phone to my phone server.
Note that, although we don't make this super clear, our generic "SMS module" is actually extremely specific to a few types of SMS modems from Airlink:
It is not a general purpose "send alarm notifications over SMS using any provider" option.
We also have a Twilio based SMS module, and there's going to be a Twilio based voice option first-party in 8.3.
But any integration with Starlink as a modem is not going to be possible first party. The best experience would have be with a custom module ex working from our notification profile example module, but you could achieve one way notification relatively easily with a scripted pipeline block if Starlink provides you with an API that you can call from scripting.
Thank You. Essentially what you are saying is we can run SMS via the Twilio SMS module and we were able to get Voice to work over AWS Chime. Phil T. above also suggested voice via Asterisk. Essentially both utilizing a 3rd party service over Starlinks internet.
i’ve had better luck triggering sms and sip notification reliably after tweaking buffer sizes and adding a small delay between sends.
I’ve been running a similar setup and had a few hiccups at first too. The key for me was using a sip provider that allowed adjusting port settings and had decent support for NAT traversal. I had to tweak some firewall rules and SIP ALG settings on the router to get reliable two-way audio. Latency wasn’t a big issue, but packet loss was until I fine-tuned the QoS settings.
For alarm notifications, I’d avoid tying the system directly to Starlink hardware. A small webhook service can receive the event, check whether the connection is available, then send through a supported provider like Twilio. That also gives you retries, logging, and a fallback path when delivery fails.
For less urgent follow-up, I’ve used TCPA-compliant voicemail drops alongside SMS so people can get the message without a live call. Just make sure recipients have the required consent and keep opt-outs and quiet hours handled properly.
