When I start the FactoryPMI Designer I get this error.
java.lang.ArrayIndexOutOfBoundsException: No such child: 2
at java.awt.Container.getComponent(Unknown Source)
at com.jidesoft.swing.JideSplitPane.setDividersVisible(Unknown Source)
at com.jidesoft.swing.JideSplitPane.componentHidden(Unknown Source)
at java.awt.Component.processComponentEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
FactoryPMI v3.3.2 (build 2754)
Java: Sun Microsystems Inc. 1.6.0_14
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at java.io.FilterInputStream.read(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(Unknown Source)
at com.sun.deploy.net.HttpDownloadHelper.download(Unknown Source)
at com.sun.deploy.cache.Cache.downloadResourceToTempFile(Unknown Source)
at com.sun.deploy.cache.Cache.downloadResourceToCache(Unknown Source)
at com.sun.deploy.net.DownloadEngine.actionDownload(Unknown Source)
at com.sun.deploy.net.DownloadEngine.getCacheEntry(Unknown Source)
at com.sun.deploy.net.DownloadEngine.getResourceCacheEntry(Unknown Source)
at com.sun.deploy.net.DownloadEngine.getResource(Unknown Source)
at com.sun.javaws.LaunchDownload.getUpdatedLaunchDesc(Unknown Source)
at com.sun.javaws.Launcher.updateFinalLaunchDesc(Unknown Source)
at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source)
at com.sun.javaws.Launcher.launch(Unknown Source)
at com.sun.javaws.Main.launchApp(Unknown Source)
at com.sun.javaws.Main.continueInSecureThread(Unknown Source)
at com.sun.javaws.Main$1.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
is a known issue with recent versions of Java 6 (update 12 and up, iirc). It is totally harmless and will be fixed in the next major release.
The secoind issue:
FailedDownloadException: Unable to load resource: http://127.0.0.1:8080/gateway/designer/designer.jnlp
is not similar to the first. I don’t know what would give you that impression. Anyhow, this seems like a networking error. Check the FactoryPMI logs (usually in C:\Program Files\Inductive Automation\FactoryPMI\logs) to look for anything unusual.
Regarding the first error (no such child), by major release do you mean some 3.x version, or the next version that is now in the beta state (v4.x?)? I know it’s harmless, but the IT guys I’m training don’t like to see it. But if it’s a Java problem, I’ll just tell as much and that FPMI is catching it.
