Hi All,
I want to swap between two identical (in size) templates based on states (custom property on the main window). Which option would you suggest?
Create a template on the main window and swap between the two through the template path property (expression binding)
Place one on top of another and use the visibility property to make the templates appear/disapper based on the states
Performance-wise, would it be an issue to go with the second option? Also, I have different custom properties for both. If there is a better option I’m all ears. TIA.
